I'm doing encoding from Bluray raw videos using Hybrid. I've noticed that, even though I selected "passthrough" for the audio, it converts the 24bit pcm audio stream into a 16bit pcm audio stream. It's not a matter of mislabeling the stream either. I extracted the audio from the encoded video and compared it to the source, it is really smaller. So some conversion is happening.
Out of all the encodes I have done with PCM audio, only one properly retained the 24bit audio stream. I can remux the 24bit audio stream from the source, most of the time, but this is an annoyance I can do without.
Can anyone tell me how to keep this from happening again?
	I use Hybrid. I put it in the title, but forgot to mention it in the post itself, oops. One of its encoding options is to simply passthrough the source audio stream without any conversion. At least, that's what it does with other audio formats. But I get this with 24bit pcm. Last edited by Compositor; 28th Apr 2020 at 10:10.
	Probably a bug during the extraction of the audio. Best post in the Hybrid-Thread with a DebugOutput Level 9 of the job creation (not the processing of the source or the analysis of the source, just the job creation)
 Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
	And that when the normal log starts with:
 Cu SelurThis log is only intended for user information. It should not be part of a bug/problem report!!
 Hybrid: homepage
 Forum: public forum
 Regarding problems please read: needed infosusers currently on my ignore list: deadrats, Stears555, marcorocchini
  can I rip audio dvd @24bit and more then 48k kHz ?By rama in forum AudioReplies: 4Last Post: 21st Feb 2018, 08:29
  How do I get Hybrid to passtrhough only audio track 2?By bizzybody in forum Video ConversionReplies: 0Last Post: 9th Oct 2017, 23:16
  miniDV 16bit - 12bit Audio Drop Out IssueBy Lynx68 in forum Capturing and VCRReplies: 2Last Post: 4th Oct 2017, 06:23
  24bit DVD Audio AdobeBy mocarob in forum AudioReplies: 5Last Post: 17th Sep 2016, 20:27
  Why does Bluray TV series have 16bit and 24bit audio on same disc?By VideoFanatic in forum AudioReplies: 7Last Post: 15th Mar 2016, 14:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
